Ok what am I doing wrong here???
I’m trying to add an additional circle so that I can countersink the screw holes (need to make up for thickness of the acrylic going behind it) Measured the head of the screw and it looks like a 10mm hole will be perfect. Why is it coming out so huge???
Edit:
I bet this has something to do with it…
Why is fusion not bringing in the SVG at the right size??? When I open it in Estlcam its 1450mm like it should be but fusion is only opening it at 383.627mm. Is there a way to add a counter sink in estlcam??
