Cnc program/g code issues
for some reason the projects im trying to to set up end up as creality g code not estlcam cnc program
CribbageBoard.gcode (121.0 KB) this is the bad file
kneelingsoldiersilhouette.nc (1.3 MB) this is a good file
they dont want to work properly ,it just started doing this can someone explain this creality program was uninstalled
Try changing the CribbageBoard file from .gcode to .nc. I was able to open it on https://ncviewer.com/ and it loaded correctly.
just did that it work fine now thanks
The .nc vs .gcode appended to your cam file generated in estlcam depends on which machine you are generating code for. In your basic settings you select the machine type and can make customizations for file extension, move commands, and other gcode output options such as header or footer and have a wealth of customization options.
Make sure you select marlin if that is what you are running or grbl if you are using the jackpot.
