Cnc doesn't move
I have had this problem before but I can’t remember what the solution was. The cnc goes to the first position, drops down and doesn’t move. I think it had to do with speed settings but I can’t remember how I fixed it.
FMC Key Spacers.nc (101.1 KB)
FMC Key Spacers.gcode (101.5 KB)
From your gcode:
(No. 1: Part 91)
G00 X17.9366 Y6.9556
G00 Z0.5000
G01 Z0.0000 F3.000 S24000
G01 Z-0.7500
G03 X18.7301 Y7.7491 I0.0000 J0.7935 F15.000
G01 Y24.2492
G03 X17.9366 Y25.0427 I-0.7935 J0.0000
G01 X6.4368
G03 X5.6433 Y24.2492 I0.0000 J-0.7935
G01 Y7.7491
G03 X6.4368 Y6.9556 I0.7935 J0.0000
G01 X17.9366
G01 Z-1.5000 F3.000
You are setting your feedrates for 15mm/min and 3mm/min. It is moving, just extremely slowly.
Set all of your EstlCAM settings to mm/min
Isn’t that the same?
You should be running at around 15mm/s (900 mm/min)or higher.
Marlin expects mm/min. Depending on how you define settings in EstlCAM, you may have the output set for mm/sec, or you may be expressing feed rates in mm/s.
Far better (IMO) to use only mm/min for all settings, that way you won’t have errors in converting between mm/min and mm/,s
The control board is assuming the feedrate is set to mm/min, but the issue is that your CAM is probably set for outputting your g-code as mm/s This means it will output F3.0 when you really want F180.0
I normally use my laptop when using eltlcam but this time I used another computer which, apparently, had the wrong settings. The same thing happened last time I had this problem. I just remembered that this morning. Thanks for the help guys.
Jerry
Closing older topics, to fight spambots
