Where can I find the dimensional information on the relationship of the CNC components (or a dimensional layout)?
Thanks!
Thanks!
I don’t understand what you are asking for?
In designer language, I’m looking for the center to center (design) distances of all the conduit rails in X, Y, and Z directions. (This would be for the conduit version, if that makes my difference.)
Being more specific:
Thanks!
27.6 mm for the Standard version for everything but the z axis. The z axis is different and I don’t have it memorized. What do you need these for? That might help me understand what you need, from me. I have a blank tool holder on thingiverse easily editable and gives you the z axis center to center for the z axis
In review of my last posting, I see that I made a obvious mistake. There is no set dimension for # 1& 2 as those dimensions are set by the user.
On a related front, in using the Dewalt 660 it would be helpful to know the following instead.
Pretty sure the linked calculators on the assembly page “rails” have this info. If not I will be putting the dewalt on my machine in a day or two and can measure it then.
Thank you vicious1!
My use? I’m in the process of setting up one of your systems that I just picked up from a friend. These dimensions will help me do some simple dimensional layout work to establish my desired standoff or leg length and more and hopefully in actual set-up later.
Upon further review of your reply, I’m confused. Did you confirm that the center to center distance for items 3, 4 & 5 is 27.6 mm?
#3. I don see what those other numbers will help with.
the rails stationary and moving are 27.6 apart. I don’t know what the stationary to moving rail distance is.
