Hi Everyone,
Im thinking of swapping out the timing belts for a rack and pinion drive. Why, well I have had so much problems with the belt system jumping and destroying projects. I can buy them very cheap here in Australia, so I thought why not. My problem is that the T-Belt and drive are 16T, but the rack and pinion is 32T. Im assuming this wont work, so what do I have to change in the software to work with the 32T.
Thxs people
Rob
Any possibility of 3D printing a pinion and rack in the configuration you need? Maybe in nylon or one of the fiber reinforced filaments?
See this thread:
https://forum.v1e.com/t/printed-r-p-x-y-drive-for-mpcnc/14341
Are you sure the belt is skipping? That is not a common issue. Motors skipping is more common and sounds like it is skipping teeth. Rack and pinion will not make the motors act differently.
Maybe start by describing the issue you are trying to solve and we can help with that.
