Can't move axes with cncjs (but Estlcam is fine)
As the title says…I have the “cncjs” server running, connect a browser to localhost:8000, connect the USB port successfully…but nothing when using any of the interface controls. I try to send a “G0 X0”..and just nothing and the motors are not energised.
But when I open Estlcam and start the controller - I can moves the axes around just fine…am I missing a step?
In-case anyone else ever has the issue….it turns out that I used the “Controller” option in Estlcam and inadvertently re-flashed my Arduino and over-wrote (?) the Marlin firmware with Estlcam’s own firmware (which does work, but with a limited feature-set for RAMPS 1.4).
CncJs does not support a board with the Estlcam firmware, so that’s why it didn’t work.
