I’ve tried and tried to solve this. I’ve been trying to set the VREF with no luck and it’s really frustrating because my associates is in electrical technology.
So I connect my multimeter to 12v ground and measure VREF at the top of the pot. It reads 0 for almost the whole rotation of the pot except for a small spot thats in the .600-.650 range. My first set of DRV8825s did the same but only read into the .400 range.
I researched and researched and thought it was just a bad RAMPS board so i replaced it and went ahead and ordered a brand new set of DRV8825s. They look like the the kit ones for sale on here.
With the first set of RAMPS/Drivers I also set the Z axis one to around .420 and tried to use the controller to move the Z and it didn’t move at all.
Picture of the board with only one driver on.
Please help me figure this out. I want to get this thing running.
Did you buy everything from here?
Bought some stuff from you but none of the electronics. -
Are you using end stops?
No end stops yet -
Are you using all my recommended parts?
Yep using everything you recommended
