ok, i must have messee up the post about v1.0. I triedto flash 1.0 but when compilation started I got massive errors, see below. (Theres much more of the same errors repeating)
Build options changed, rebuilding all
In file included from sketch\MarlinConfig.h:26:0,
from sketch\Marlin.h:36,
from sketch\Marlin_main.cpp:223:
pins_RAMBO.h:178:29: error: pasting “/* AUX-4*/” and “_RPORT” does not give a valid preprocessing token
#define BEEPER_PIN 79 // AUX-4
sketch\fastio.h:64:32: note: in definition of macro ‘_TOGGLE’
#define _TOGGLE(IO) do {DIO ## IO ## _RPORT ^= _BV(DIO ## IO ## _PIN); } while (0)
sketch\buzzer.h:62:7: note: in expansion of macro ‘TOGGLE’
TOGGLE(BEEPER_PIN);
sketch\buzzer.h:62:14: note: in expansion of macro ‘BEEPER_PIN’
TOGGLE(BEEPER_PIN);
pins_RAMBO.h:178:29: error: pasting “/* AUX-4*/” and “_PIN” does not give a valid preprocessing token
sketch\fastio.h:64:59: note: in definition of macro ‘_TOGGLE’
TOGGLE(BEEPER_PIN);
TOGGLE(BEEPER_PIN);
sketch\fastio.h:62:41: note: in definition of macro ‘_WRITE’
#define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0)
sketch\buzzer.h:70:7: note: in expansion of macro ‘WRITE’
WRITE(BEEPER_PIN, LOW);
sketch\buzzer.h:70:13: note: in expansion of macro ‘BEEPER_PIN’
pins_RAMBO.h:178:29: error: pasting “/* AUX-4*/” and “_WPORT” does not give a valid preprocessing token
sketch\fastio.h:51:51: note: in definition of macro ‘_WRITE_C’
{DIO ## IO ## _WPORT |= _BV(DIO ## IO ## _PIN); } \
sketch\fastio.h:74:21: note: in expansion of macro ‘_WRITE’
#define WRITE(IO,V) _WRITE(IO,V)
sketch\fastio.h:51:78: note: in definition of macro ‘_WRITE_C’
