Hi all,
Finally finished my build and now trying to move over to the software side of things – what a fun project this has been so far!
Unfortunately I am only seeing a blue LCD screen - no text - when I power up using the kit power supply. I am also using the dual end stops and purchased the proper board from this shop, so firmware should be flashed. I have tried flipping the connections around as advised on this forum to no avail (I either get a blank blue screen or a flickering screen with a clicking sound - almost like a turn signal in a car).
I have also tried to plug the machine into my computer (Macbook Pro running Mojave). In the past I have had some issues with connecting Arduino or Arduino-compatible boards to my laptop and believe it is due to the USB dongles this laptop requires. I have found success with purchasing USB-C cables, so no dongle is necessary. For this project I have a printer-style USB to USB-C cable and can see the RAMBo show up in my system information.
Repetier says the machine is connected and can connect to it but it is not moving, in any direction, when I issue commands to it. I saw some links to firmware downloads that might be causing USB communication issues on this forum - but the links are now dead (posts were from 2016).
Attaching photos of my wiring to the board. Can anyone help?
