So this is my solution. It bolts onto the X carriage, and holds a J-Head, with room for a zip tie. The other half is a piece that I made for my other printers that clamps to the other side (with room for a zip tie) to hold a DC42 IR Z probe. The original holder for that slipped in between the shroud and the fan, which was great as far as it went, but I kept having to recalibrate every time something bumped the fan shroud, so I solved it by setting a fized distance from the sensor to the mounting groove on the Jhead, which I could do, since I was actually holding it in place to the extruder with the threads cut into the top for the Bowden fitting.
I did that part a couple years ago in TinkerCAD, because it was good enough. I can see some things that were actually pretty bad in that model now, but it works, it prints well enough, and does the job I want it to.
I put main power to the printer for the first time. Still no limit switches, but the firmware will allow me to move it without. X Y ad Z axes move as expected, including the dual Z driver, so I’m happy with that. Everything moves in the right direction too. Bonus, since the motors came with keyed connectors. Great for the MKS board, they match, but difficult to just swap the motor direction. If they were wrong, I’d have fixed it in firmware.
I don’t have a working 3cm fan for the hotend, so I’ll need one. Still need to figure out part cooling, too. The X carriage looks so empty without the bulk of the extruder there.
Progress has definitely slowed down, as I come to the end of what I can do with parts ready to hand. I bought a new multimeter today, so I could test the heater cartridges that I have. Of course this means that I’ll find one or more of the others that I own right away.
I need something to hold the IEC power plug. Deciding between milled and printed.
I still need to mount the heated bed, connect up the bed thermistor and power, decide if I want to use the offboard MOSFET to keep the power wires shorter, and loom all the wiring together.
Wiring harnesses are a weak point of mine. I always want to leave room for extra so that I can move stuff after, and it always bites me in the end, as I have extra wire with nowhere to put it. It seems though that every time I try to make things just the right length, I need to move something and really needed that extra 3" of wire to do it. I designed my current printer with a big empty space in one of the Z towers next to the control board, and it’s stuffed full of extra wire. Naturally, I haven’t needed a millimeter of the extra wire in it, but I don’t want to re-crimp all of the wire ends either.
This printer has no such space provided. Chances are pretty good that I won’t be replacing the control board in this printer, though there does exist the possibility that I’ll want to use a Duet, because I like them… But more likely this will end up being my son’s printer, and I’ll build myself a CoreXY.
I’m very impressed with how this printer has gone together, despite me doing stuff that is different from the original design at almost every turn. I’m using 1/2" plywood, not 3/8" as designed. 20T pulleys and idlers (Ok, I modified the parts to make that work, too.) and a control board that happened to be convenient to hand instead of the intended one. I lucked out in that my PSU mounts to the frame the same as the intended one though.
