Afternoon all
Can anyone tell me how to ajust steps in this post processer (marlin mm test 5 ) this works perfect except the steps are wrong
, ive set the steps on marlin mode and when jogging the Lowrider via marlin mode thay are exact ,
When i run toolpath on my strut brace (1004 mm ) and cut via sd card my cut comes out 35mm too short
can anyone help ?
Thanks in advance
Luke
The post processor doesnât do this. (well it could but it would be a factor of 25.4 off).
This has to do with your design getting imported to your CAM and that conversion or scaling ration. Thinking pixels to mm instead of mm to mm. Maybe.
Export your vector in mm or inches instead of pixels.
The part im referring too is the strut brace download directly from ryans v1 site , ive also tryed to cut the same file in carveco make and cuts to the right size
When you import the DXF into your program verify the size before you cut it. That can be done with a measuring tool or setting the background grid depending on your program.
The Post processor just translates the coordinates into a language the CNC can read it does not scale anything. The problem is in the CAD for sure (You verified the file in another program). I canât help to much since you are not using any of the software I have.
OK, just a quick thought.
Ryanâs designs are made in âMMâ.
Is the Aspire project designed in âINâ?
I have seen that happen in a few CAD/CAM packages, the translation of the increments can be skewed through the PostP.
That is done in CAM. The Post processor HAS to output in mm/min which has hard-coded and has no relation to your design size. The PP does nothing to resize a design. The CAM program outputs coordinates not the PP.
this would make it 25.4x off.
This is .96x off. It doesnât really make sense. Unless it is a pixel to mm thing like we used to see with old inkscape versions.
It was just a thought. Seen a lot of software measurement weirdness in 28 years in the printing industry, even computer to computer.
No sure but ive cut a basic square from aspire and that perfect, using marlin test 5
so maybe your proberly roght ryan woth your old Inkscape theory,
Another problem solved:)
I must add what a amazing product and community u have built ryan im just gobsmacked its all free
Your efforts and work ability is well worth paying for
Thanks again
Luke
Did you just import the DXF into Aspire? Or was there some other software in between?
Yeah the software toolchain can be a pain but once you get it right you will not make that same mistake twice.
For some reason, I remember David finding a crazy issue. At some point Inkscape change from a pixel count of 93 to 95 per mm or something like that. It caused issues for a while until he found it.
Can you share a screenshot of your screen when you âSave Toolpathsâ showing the post processor section?
Also, a screenshot of your âMaterial Datumâ screen aka âJob Setupâ
I just want to compare something.
