Another quick, super satisfying project!
Another quick, super satisfying project! - August 19, 2023
Sheet metal scrap used in this project:
• 16 GA. (.060 thick) Hot Rolled Steel Sheet
• Bought online from Metals Depot - https://www.metalsdepot.com
Dowel rod (broom handle?) wood used in this project:
• Diameter: 26 mm
• Length: ~98 mm (or so)
• Possible source: Birch Wooden Dowel Rod | 1" Diameter x 36" Long | Pack of 2 - Amazon.com
~~ PRINTABLES LINKS ~~
~ Printed Edge/Lip attached to dowel - used in this project ~
Printed Edge/Lip attached to wooden dowel rod in making filament spool holder by Doug Joseph (design8studio) | Download free STL model | Printables.com
This model is so simple that I feel sheepish uploading it, but since I published a YouTube video about the make, here it is. A printed edge/lip attached to wooden dowel rod in making filament spool holder.
NOTE: I designed the print before I sorted out which screw I would use, so I printed with enough perimeter walls to allow the center hole to be drilled out larger, which I ended up doing just that.
~ LowRider v3 DIY CNC ~
• NEW dust shoe for LR3 with NEW retainer C-clip for Vacmaster 2.5" Shop Vac hose - Removable Dust Shoe v1.3 - with retainer C-clip for Vacmaster Shop Vac hose - easy to attach and detach the hose! by Doug Joseph (design8studio) | Download free STL model | Printables.com
• LowRider 3 CNC Drag Chain Shield (protection from vac hose getting tangled underneath drag chain) v2.0.1 - LowRider 3 CNC Drag Chain Shield (protection from vac hose getting tangled underneath drag chain) v2.0.1 by Doug Joseph (design8studio) | Download free STL model | Printables.com
• LowRider 3 CNC - printed holder for Makita Router Wrenches and Collets - LowRider 3 CNC - printed holder for Makita Router Wrenches and Collets by Doug Joseph (design8studio) | Download free STL model | Printables.com
• LowRider 3 plasma CNC - Drag Chain Mount revised for large 20x40 drag chain (v1.13) - LowRider 3 plasma CNC - Drag Chain Mount revised for large 20x40 drag chain (v1.13) by Doug Joseph (design8studio) | Download free STL model | Printables.com
• Various LowRider 3 CNC remixes -LowRider3 Collection by Doug Joseph (design8studio) | Printables.com
~ DIY Router Table ~
• Makita rt0700 dust extractor for 2.5 inch shop vac hose v1.0 - Makita rt0700 dust extractor for 2.5 inch shop vac hose v1.0 by Doug Joseph (design8studio) | Download free STL model | Printables.com
• Dust Collection Port (v1.0) - designed for 2.5" hose from Vacmaster shop vac - Dust Collection Port (v1.0) for DIY Router Table - designed for 2.5" hose from Vacmaster shop vac by Doug Joseph (design8studio) | Download free STL model | Printables.com
• Dust Collection Reducer Adapter 4-inch Hose to 2.5-inch Shop Vac hose v1.0 - Dust Collection Reducer Adapter 4-inch Hose to 2.5-inch Shop Vac hose v1.0 by Doug Joseph (design8studio) | Download free STL model | Printables.com
• 2.5" shop vac hose connector/adapter, tapered end - printed replacement for a stock Vacmaster part (v1.0) - 2.5" shop vac hose connector/adapter, tapered end - printed replacement for a stock Vacmaster part (v1.0) by Doug Joseph (design8studio) | Download free STL model | Printables.com
~ DIY Panel Saw ~
• [DIY Panel Saw] Z mount (v7a) - [DIY Panel Saw] Z mount (v7a) by Doug Joseph (design8studio) | Download free STL model | Printables.com
• [DIY Panel Saw] Pipe Inner Endcap Nut/Bolt Holder (M8) for .75" ID pipe - [DIY Panel Saw] Pipe Inner Endcap Nut/Bolt Holder (M8) for .75" ID pipe by Doug Joseph (design8studio) | Download free STL model | Printables.com
~~ PRODUCT LINKS ~~
~ Consumables ~
• Heavy Duty Cleaning Towels (paper based shop rags) - Amazon.com
• Titebond Original Wood Glue, 16-Ounce, 2 Pack - https://amzn.to/44vKOQc
• Elmer’s E7050LMR Carpenter’s Wood Glue, 1 Gallon - Amazon.com: Elmer's E7050LMR Carpenter's Wood Glue, 1 Gallon : Everything Else
• Makita RT0700c Compact Router - Amazon.com
• Inline Switch 5 PCS, Cord Appliance Switch used for LowRider v3 - Amazon.com
• 48’’ Blue T-Tracks 4 PCS - Amazon.com
• Router Table Insert Plate (235 x 120 mm) for Makita RT0700c - Amazon.com
~Dust Collector~
• Remote Control Switches used for Dust Collector [No longer available] - AC 110V/120V/240V/ Relay RF Remote Control Light Switches for Pump Security Systems etc with 328ft Long Range for Household Appliances, Pump,Lights Ceiling and Electrical Equipment - Amazon.com
• Remote Control Switches used for Dust Collector [Another listing] - Amazon.com
V1 Engineering Documentation, Low Rider CNC, v3:
My PayPal tip jar: PayPal.Me
Various LowRider 3 CNC remixes:
View all my models and remixes on Printables:
*Amazon product links are affiliate links.
Cool. Have you a video about your DIY panel saw?
I think so… will try to check
Well found this. It is probably not as much detail as one would hope.
“Wall-mounted Panel Saw - custom sliding rig - cuts steel, just about anything”
Thanks. Very interesting.
Hey, I just remembered that, even though I did not make a detailed video on the making of it, I did chronicle it on a thread here in the forum. Here’s a link:
I also did a LR2 based panel saw
There are some pics here. It works well.
