Hello All,
I must say that this is one of the most helpful and true community-oriented forums I’ve been on is quite some time. I want to have a CNC machine for a variety of reasons but a lot has to do with not being on my feet so much and letting the CNC do things I no longer can do myself like wood carving and inlay work.
Here’s my “Dream” machine - a full sheet 4’ X 8’ with a z reach of at least 6" and I would like to work with material up to 4" in thickness, with a dropdown table and a rotary “A” axis that can turn 4" material as a minimum but prefer 6".
I like the portability of the Primo MPCNC but wanting full sheet capability its best to go with LR3 it seems, but what height of a Z rig can I really go to considering a possible drop table with an insert for the rotary axis with I have seen on a number of builds. I like the thought of adding a Laser or even Plasma cutter if a table insert was made for small soft steel parts (Not too often I would think but having that capability would be nice.
Ultimately this is what I want to do - building furniture and cabinet parts, lots of carving involved (with some by hand carving clean-up) inlays on panels as well as 3D dimensional signage using HDU or other High Density foam and hand carving as well. I don’t envision working with much metal, but that may change since I’m learning how to stick weld right now and this gives me some ideas with a welded table base but it may just be too heavy for me to move around, so looking at a home-built table like the bench below.
With the Primo I could initially use my current bench that I completed last year when I was still feeling “froggy” but after some back surgery later not feeling quite so froggy yet…grin. Here’s the bench I currently have, 4’ x 8’ 1.5 inch top. it’s a beast but easy to move around with heavy-duty casters.
Like everyone these days money is tight, especially being a retired disabled Vet on VA/SSA fixed income. But, that’s why these builds are so cool for they “give you just what you need and then some” and the most reasonable in terms of costs involved. I don’t know which way to go at this point. I know I will need the Z depth, and although a full sheet is a great thought, but if I can use software that allows for paging or reindexing as a full sheet is moved through it (Primo build) I might be able to go with a 4’ x 4’ but with my desire for the rotary axis going almost the length of the top (with built-up spindle bases and sliding bedstock) again drives me back to the LR3. The workbench already takes up a lot of room but still would have some room at the back of my shop for a full sheet CNC as I’m cleaning out 30+ years of personal flotsum and many of my Dad’s stuff collected from 50 years as a Carpenter/Contractor.
You folks here have already gone through this “Gnashing of teeth”…lol, but looking for advice as to which way would be best in most opinions from those who are doing it and if I can only make one choice based on what I would ultimately like to do. Thank you so much in advance for any suggestions.
Here is the dimensions/Parts list I just ran for a 4’ X 3’ Primo build and will probably go with the Makita
If anyone has any suggestions on this I’m all ears. Can I go this big with the MPCNC? I also want to drive this mainly by wireless or USB directly connected to laptop and really liking DeskProto 7.1, but have other capable software for sculpting/carving digitally.
GrumpySarge_MPCNC Dimensions List 4 foot X 3 foot.zip (101.5 KB)
