A, B, and C tension bolts/nuts
Putting my build together and I noticed that some of my A, B, and C tension bolts/nuts are still loose as they were never tightened (or loosened further) to line up the 90 degrees - this is the big center assembly that holds the spindle and accepts an X and a Y tube (also the two Z tubes). When one is satisfied on how things “feel” should all tension bolts be “tightened” - just to where the nut barely touches the plastic? or is there some other “factory torque spec” such as “gutentight”? (joke)
Just snug them so the bolt head and nut just touch the plastic. The plastic will relax over time, so just touching helps keep it in place. You should still be able to turn the bolt head and have the nut turn with it if that makes sense.
