This is interesting. Do you think that the carriage would be more stable with 2 bearings on each rail. Might give a little more lateral stability.
I am definitely interested in doing something like this.
Silly idea, on the router holder (where there are 7 holes), add on both sides linear rails.
On the rail carriage you could make a dust shoe with those rather stiff bristles.
Not sure if it would work but that way the dust shoe always drops to your workpiece and when the router goes down the carriage climbs up the rail so you have an always perfect”vacuum”.
Obviously the bristles might wear in time, not sure what happens then:)
ill give it a try. i have to modify a couple things might brake it into a couple different parts to make it easier to print
Good luck!
Nice!
Is that a watercooled spindle?
It is indeed, kinda went over kill when i started building the thing. Hence the x axis upgrade and maybe y linear rails down the line
Cool!
Might I ask, was your x belt designed to be like this? It looks like the belt holder should be few mm’s up. No?
Yeah im need to raise them slightly and add a way of tensioning the belt with a screw instead of pulling with pliers and a ziptie. Once is calibrated ill add that im still debating if i want to machine some metal parts for it
So how´s progress?
Been extremely busy with work so I haven’t had too much time to mess with it and texas heat is nasty. I have a couple things i need to adjust on the spindle mount. I was thinking about making it out of metal to have a perfectly straight one
You are so far overboard! May i ask, do you have a running tally??
Uhm ive tested every version and made them run and used them then i get a new idea stuck on my head and only way of getting it out is doing it so im always ripping my machines apart and re building them. Im about to finally wire this new one tomorrow and test it. Need to make a couple cutting boards for a few friends and need to machine some aluminum parts for a new 3d printer
