1.5in thick 6061 aluminum plate
Ive been just updating the stock height…
When i bitch about fusion changing the entry point, thats because im just modifying the same toolpath… not even a duplicate.
I just lost a step, -y so its into the thickest section of the inner ring and im okay with it.
Ive been babysitting it since i restarted… bout 25min in was when it happen.
When the shavings look like cotton candy youre cutting a lot of the sidewall…
Luckily i tighetened it all back up so a hand on the gantry to reduce chatter and it ate it away… im 50% into this cut which was 6.5 deep… so probably 35mm ish… im mic it in a bit and upload the pic that just failed
