Hi All,
I’ve nearly Finished my Low Rider V2 CNC. I have it running on a Trigorilla V1.1 board. Its configured using the Firmware from the Website for the DL Lowrider CNC.
I have Dual Y endstops and Dual Z endstops and have the Physical connections exactly as per the Doco
https://docs.v1engineering.com/electronics/dual-lr/
When initially setup the Directions where correct for control,I.E.
X+ moved to right,
Y+ moved away,
Z+ lifted gantry.
When homing X and Y this also worked Perfectly, The Both Homed back to 0 (Minimum)
However, when Homing Z, the gantry lifted, not lowered.
I edited the Configuration.h and changed the Value
#define Z_HOME_DIR +1
to
#define Z_HOME_DIR -1
This now Homed the Z axis down to the Switches, but it didnt stop when the Endstops Activated.
I have the Z_Min Switch connected to Z_Max on the Board
I have the Z2_Min Switch connected to the X_Max on the Board
When I check using m119
I see the Following
With Z_min switch triggered
Recv: x_min: TRIGGERED
Recv: y_min: TRIGGERED
Recv: y2_min: TRIGGERED
Recv: z2_min: open
Recv: z_max: TRIGGERED
Recv: z_probe: open
With Z2_min switch triggered
Recv: z2_min:TRIGGERED
Recv: z_max: open
Recv: z_probe: open
so I’m pretty sure I have the right Physical switches connected to the right Physical Ports.
My endstops are defined
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
#define USE_XMAX_PLUG
#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
In configuration_adv.h I have the Following
#define NUM_Z_STEPPER_DRIVERS 2
#if NUM_Z_STEPPER_DRIVERS > 1
#define Z_MULTI_ENDSTOPS
#if ENABLED(Z_MULTI_ENDSTOPS)
#define Z2_USE_ENDSTOP XMAX
#define Z2_ENDSTOP_ADJUSTMENT 0
#if NUM_Z_STEPPER_DRIVERS >= 3
#define Z3_USE_ENDSTOP YMAX
#define Z3_ENDSTOP_ADJUSTMENT 0
#endif
#if NUM_Z_STEPPER_DRIVERS >= 4
#define Z4_USE_ENDSTOP ZMAX
#define Z4_ENDSTOP_ADJUSTMENT 0
#endif
#endif
#endif
I have had a look at a few other posts on here and am now very confused.
Does anyone have any Idea’s?
Thanks
Matthew
