Hi, in the calculator the minimum height is (70mm) and shows conduit size of 64mm.
I download the newest version of the MPCNC with the new foot, after mount the first base leg I felt like is too short, can you please confirm if it will work with this size?
I think I understand a bit the OP’s concern, but there’s not a very clear answer. It depends a lot of what tools finally are mounted and how.
My first build, which I kept pretty short, but not as short as yours, I have to modify as the T8 goes through the floor.
My other build which is running more or less, lost quite a bit of mm just the way the router was fixed. I guess this will be further reduced when I change to ER11 collet.
I’m thinking already, depending on the job, to have parts ready to interchange.
Longer tubes for the legs would be the easiest, I’m thinking already about a complete Z-axis replacement in different lengths.
Hi, That is what I cut 6.4cm but after I set the foot and the bottom corner, I wonder if this is not too short? Did someone already made a short leg like this?
My MPCNC is not completed yet, I am just finishing printing, I was looking at the web and did not find any MPCNC with legs short like this.
In your experience would I proceed or maybe a good idea to increase the length?
I attached the pic for the calculation and the actual size of the foot with a roller for you to get an idea.
As long as you can get whatever you’re going to be milling under the endmill, it should be alright. Mine are longer, but I have a wasteboard on top of my table.
my x axis only goes down I am using a ramps board and all is wired right acording to instruction. but weather i go to a positive or a negitive number on the z it goes down.x and y work great. can anyone help with some sugestions im thinking it must be firm ware
