Z Axis Parking Blocks
Got my LR3 up and running, and had a few close calls with the Z axis dropping after powering down. I also need to frequently remove the gantry from the table in its current location, so I whipped this up in tinkercad:
Mine fit with just enough resistance to keep them from falling off, but are easily removed after booting and homing Z.
Nice! Do you find yourself placing the these parking blocks on both sides, or is just one side good enough to avoid damaged from unwanted drops?
I have them on both sides. I home everything before shutting down, and the side with the router is the main offender, but having them on both is helpful when I pull the whole gantry off my table.
In have also printed a set of these, but found them just a little too long for my exposed Z screws. I sanded a bit off the ends and they work great.
Mike
