Hello all,
I just ordered the kit and i have been assembling the machine. on the website https://www.v1engineering.com/assembly/z-mount/, i have both the pineapple coupler and the aluminum coupler, which should i use?
Hello all,
For T8 leadscrew, use the aluminum spring coupler, if you are using the 5/16 threaded rod, then use the pineapple coupler. I’m pretty sure the kits ship with the T8.
Ok, that was my problem, i wasn’t sure if the kit came with the leadscrew or the the 5/16 threaded rod.
Yup T8 and aluminum coupler. I will see if I can clarify the instructions.
thanks alot
