Post
After 3 days of trying to level my LR3 Z axis I’m about ready to tear it apart and put my LR2 back together. I don’t get the expected results after entering M666 and M500. It seems like it either doesn’t change or it gets worse. If I try reversing what I did it only changes a bit.
I am using the Rambo board and the steppers are from V1E. I previously posted about my issues with one of the Z steppers seeming weak but I didn’t get much help in resolving that so for now I have to help both sides up when homing Z. I have confirmed all the suggested fixes in other posts about the same issue.
However my main problem now is getting Z leveled. I am following the instructions in the documentation. I home Z, probe (using a V1E touch plate), record the results, repeat, move to the other end and do the same thing. My results are usually a difference of 1.3-1.7. I have tried entering the offset with both plus and minus values but again it either stays the same, gets worse or doesn’t change.
Are these M666 changes cumulative or are they separate offsets. How do I get back to what I started with if the change doesn’t do anything?
Also, when I home Z now it raises up until it contacts both switches, backs off, raises back up slowly until it closes the switches and then drops a little. Is that drop the offset that I have entered?
A thought just came to me as I was trying this yet again. Where are the Z steppers supposed to be connected on a LR3 Rambo with endstops? I followed a picture on the site for a dual end stop Rambo but I thought I heard somewhere that the z connectors are in series. If that’s true how would they adjust individually? I have them connected to the Z connectors per this picture:
This seems consistent with what is happening to me. Both sided drop an equal amount after it homes.
I have the endstops connected as Z1 to Z_MAX and Z2 to X_MAX.
I started here:
A difference of 1.28 with the left side Z1 traveling further. I entered M666 -1.28 M500. I then got a difference of 1.28 again.
Then:
A difference of 1.7 with the left side Z1 traveling further. I entered M666 -1.7 M500. I then got a difference of 1.86.
Then:
So I tried entering positive values and the last 2 tests gave me 2.37 and 2.4 2 times in a row even after entering the values and saving them.
What should I do? I’m pulling my hair out.
