Your numbers suggest you are running a 16T and a 20T pulley. Please double-check them.
If that is not the case run $ss in the fluidnc terminal and show us the output please.
Nope, As they are shipped they should work perfect, no way I would ship them not working…but accidents do happen so let’s double-check the previous things mentioned.
I thought it might be grub screw, as I saw that comment here enough times, but that would look more like a slip, rather than a racing ahead. Since the one motor does move ‘10’, and the other one moves more, I’m assuming it’s ‘racing ahead’ somehow, rather than the other one lagging or skipping.
The following situation that I encountered does not sound likely to be your issue, as a differing number of teeth on the pulleys seems more likely. However, I just thought I would mention it.
I had an unnecessary trailing space in my config.YAML file and it caused one of my Z steppers to move much farther than the other one. Checking my file for the unneeded trailing spaces fixed this. It has to do with how the firmware parses the config file, and apparently unneeded trailing spaces are a no-no.
Yah, I read your commentary on that about a week ago. My first thought was; I should help make that scanner better.
As for this current situation, I didn’t touch the config file. So, if I’m having this problem based on config, I’d expect others to have the same. But, I will check anyway eventually.
I only have 3 pulleys (x,y1,y2), and when I built the thing, I thought they were all the same. Barring the proctology exam of the config coming back clean, I’ll have to take those all apart and inspect.
Since I’m a noob with respect to LowRider builds, I’m sure there’s something I could have done to put it off track, so thanks for all the suggestions.
Well, I took the thing apart, and sure enough, the pulley on the left has 20 teeth on it instead of 16. I can assume the one on the right has 16, because it’s already moving the expected distance. I didn’t check the x-axis, but now I guess I should.
I seem to remember vaguely counting teeth on a pulley when I first got them, and I must have gotten lucky and counted one that had 16 on it.
This is all from the kit, so Ryan might want to check other pulleys to be doubly sure.
Nah, I already ordered new stuff. It will waste time and CO2 shipping one more by itself. I’m good. Already installed the new one, and I’ll put the thing back on the rails tomorrow and continue on.
In hindsight, I should have diagnosed to that as well, but I’m more electronics and software minded, so my first thought was ‘driver is configured wrong’, but the astute in the crowd here diagnosed it correctly immediately!
Thanks for your support, now on to squaring and crowning.
As an aside, I really like this jackpot board. It’s feeling like I can standardize a few different machines around it.
You’d be surprised how often that happens. Like when you go to the dr and you tell them you have this cough. They ask you what color the phlegm is and immediately prescribe you the right medicine.
If it is off by 20%, it is a 20T pulley. If it is off by 200%, it is the wrong microsteps (used to happen more often with Ramps). If it is off by 4%, you tried to calibrate it and over tuned.
