Just wondering if there is supposed to be a difference in height between the X-Min and X-Max sides of the V4? I had two strips of MDF stacked similar to the X-Min side, but the X-Max was too high. So I removed one layer and now the X-Max seems too low. Any idea what the offset should actually be? I’m thinking of just planing a 10’ strip of 2x6 to the correct thickness to even things out.
I’m assuming they should be the same. In the picture, the left side is quite a bit higher on the Z screw. Have you homed the Z axis? In that picture, it doesn’t look like it.
Keep in mind the endstops have about 1/4 to 1/2 inch adjustability each!
Both sides of the table +X and -X should be at the same height. You should not have removed the section in the right as shown in your picture.
