Startup
<Idle|MPos:0.000,0.000,67.000|FS:0,0|Pn:X>
$SS
[MSG:INFO: FluidNC v3.7.8]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:INFO: Machine LowRider]
[MSG:INFO: SPI SCK:tgpio.18 MOSI:gpio.23 MISO:gpio.19]
[MSG:INFO: Stepping:I2S_static Pulse:4us Dsbl Delay:0us Dir Delay:1us Idle Delay:255ms]
[MSG:INFO: User Digital Output:0 on Pin:gpio.26]
[MSG:INFO: User Digital Output:1 on Pin:gpio.27]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (0.000,1220.000)]
[MSG:INFO: Motor0]
I’m back with a problem. After a recent crash while attempting to carve the cup from Estevan project page - my x axis motor has stopped responding to controls.
I can see on fluidic the “jog” happening but the motor stays dormant.
However, when I use the command $MD to disable the motors, I can feel the resistance go away from the motor and when I enable the motors I can feel it return.
I have a new motor in bound, but I’m afraid it’s not gonna be the solution.
Any ideas?
I’ll snap a few pics of my current setup when I get back home this afternoon.
Check your wiring. If you have a loose connection you might be losing one coil in the motor. I would think this would make a noise when you tried to move but possibly not. Still always good to verify your wiring
Show the full contents of $ss , from FluidTerm if possible, or a couple of times from the WebUI if not.
If you swap a TMC2209 between another position and the driver for the X motor that you are having problems with, does the issue follow the TMC2209 driver or stay with the X motor?
ok
<Idle|MPos:-1149.520,10.000,-4.000|FS:0,0|Pn:P>
$SS
[MSG:INFO: Motor1]
[MSG:INFO: Axis Z (-200.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Z Pos Limit gpio.32]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Pos Limit gpio.34]
[MSG:INFO: Using spindle NoSpindle]
[MSG:INFO: Probe Pin: gpio.36:low]
[MSG:INFO: Connecting to STA SSID:NETGEAR28]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.1.243]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://fluidnc.local/]
[MSG:INFO: SSDP Started]
ok
I removed the stepper and swapped it with a new one. It worked until I reassembled it, then gave me another freeze up with the webUI saying it’s moving.
