Workshop cabinets
I designed these cabinets with Cabinet Planner, which does the layout (though I would tweak some with Inkscape after. To be honest, it’s kind of a mixed bag. I had to correct a few parts (or work around the builtin behavior for things like drawer slides). The software isn’t super well-documented, though the creator is active in its Facebook group if you really get stuck.
Alternatively, I used Fusion to manually layout another set of cabinets and though the initial construction was a little annoying, I got pretty fast at it after a while, and I found it much easier to customize/check the results out of Fusion.
So, going forward, I’ll probably use Fusion and its 2D arrange functionality for future projects.
