But it seems that this bit is not really made for pocketing with a CNC? After the first layer I stopped because at the bottom I created a lot of burn/smoke.
Is this the right bit and I have some mistakes in my Workflow (i could provide details from estlcam)? Or am I using the wrong tool for the job?
I got it in 6mm and I use it strictly for the last “peel”, so to speak. I have a pocket that is smaller than the one I want by 3mm on each side and then have another one where I just do a cut inside with the round one. Might work for you, too.
If everything burns, turn down the RPM, maybe go slower as well.
You would add the radius of your ball nose bit to your pocketing operation as the “Schlichtzugabe”, then do a second operation with the ball nose bit just as a hole, not a pocket.
Well, the rpm solved my problem. I even could increase the Feedrate. But I will keep the idea with 2 bits in mind for situations where I cannot use my bowl bit
