I didn’t buy the kit from V1, I purchased all the components individually and printed my own 3D Printed parts.
I’m not sure if this is a stupid question… how long are limit switch wires supposed to be? How long are the touchplate wires supposed to be? (I’m using this for my touchplate) → Amazon.co.uk )
Do I just use an arbitrary length (50cm?) and extend the wires if necessary? Or are there predefined lengths to use? I’m guessing it will depend on the size of the build. I can’t see any indication in the calculator or in the instructions.
I’m at a similar point - I’ve just finished building mine - just come to wire it up and the 22awg wire I ordered is too big for the dupont connectors, I managed to get a wire crimped ok, but couldn’t get them into the connector! Needs to be under 1.5mm and I’m struggling to find anything!
FWIW - I made all of mine 120cm as per the kit, but I’ll shorten them as I wire them up…
I’m going to do the same and shorten / lengthen as needed when I get to that point. I think I’m just overthinking at the moment (and I’m only just doing the core at the moment, nothing else done yet).
I have this Dupont connector / crimper kit that I’ve used with 22 awg wire previously for my 3D printer → Crimper (link is uk)
