Welcome to the fixture and jigs galore!
After a small pause, I just had a bit of time to put into this…
This project just seems to have no end, really -_-
First problem, first fixture: I ordered eyelets to hang the posts to the wall… But they are too wide…
Let’s call this a nice occasion to try milling aluminium for the first time…
Drilled 2 holes with the CNC to locate the part with screws, and took very conservative cuts for this first try…
Second problem, second fixture: I need to carve a pocket in the back of the posts to mount the fixtures
I carved a long pocket in scrap and press fitted the post inside
The margin is pretty thin, about 1mm on each side, getting the fitting just right took many attempt running the file, testing the fit, zero-ing at an offset, re-running the file, rince and repeat…
Third problem… you guessed it, yet another fixture needed: the arms were all a different thickness, most of them wider than the posts
Again, I carved a pocket to fit the arm, and ran a surfacing opération on each 10 of them …
Do not ask me why there are two pockets in there… let’s just Say the part may be hard to remove once it’s surfaced flush with the other one -_-
Last but not least, I didn’t really though out how the tablets would attach to the arms…
I opted for small pins inserted in corresponding holes between the tablet underside and arm surface
Getting the locations right was a real challenge to begin with… making a fixture to hold a curved arm tight and flat was also quite interesting…
Setting this up took a whooping 2 hours all by itself -_-
Once again… reapeat 10 Times once setup correctly
Holes in the tablet were drilled manually using a doweling jig, and it all fits with a bit of hammer persuasion
Finally all was ready for the first dry-test assembly
Now I need to hang this to the wall and decide if it’s sturdy enough for holding pottery, or if this was all for nothing
Then I’ll need to hit it with some varnish, and maybe see if I add corner radiuses and chamfers…
