1- At this time, only US / Canada shipping is available.
2- One entry per person per contest (see #4). This is will be winners #4 & #5
3- JRFrye, K Cummins, David Walling, can’t win another.
4- Patreon and Printables club members are allowed two entries, they must be consecutive posts.
Winner will be picked at 8PM Pacific, 11/5/23
To enter this weekend’s raffle you need to use a CNC machine to make a Kobalt logo, Just the stylized “O”, The Fancy"K", or the whole thing. You can plot it out, laser, carve or just cut it out. OR use The Sandify and import the DXF on your Sand Table (ZenXY or Other), or you can even 3D print a nice Kobalt logo. Have fun, get dirty! Post your pictures here!
This is my very first effort at using the LR3 to actually create something. I had to scramble to get this together in time for the contest, so the usual learning curves of EstlCAM, homing, setting Z=0, etc. were vastly accelerated. Consider this my “Crown”.
The “table” is a couple of very warped pieces of 3/4" ply from the scrap bin with little to no supports underneath, so the resulting gaps should go away once I get a better base.
First time using color core. Got some scraps for cheap. Bottom is 6° vbit. Thought I could do better with a 3mm 30° but but that just blends the colors
Nothing like a contest to get me to finally cut something with my MPCNC since upgrading to the Primo. This bigger router is causing my core to fall more easily. Looks like I need a longer pause between my tool changes.
