Derek I have attached a photo of some more specs which state 1.8 degrees.
The image in the previous post also shows 6 wires but it is a 4 wire stepper.
Hi, and welcome by the way. Specs for this look OK. 4 wire is what you need but if you get a 6 wire version, just use black, green, red, blue as AABB and ignore the other two wires.
The key is the torque and current rating. The drivers we used usually top out around 2 or 2.5A, and you don’t want to run at the limits of your drivers. Almost all NEMA17 motors have a low enough current rating, and the ones you show have plenty of torque. IIRC, you need 45oz-in at bare minimum. The ones Ryan sells are somewhere in the 60-70oz-in.
The step angle is less important, as it’s easily managed with the steps/mm setting. And it’s also simple to wire up 6 wire steppers as 4 wire steppers.
