Wild Speculation - SIP For Table
I build my house out of SIP’s (Structural Insulated Panels) and it is amazing how rigid 2 sheets of OSB with foam between them is. We had a damaged piece that was 8’ long and only 16" wide that two adults could stand on with no problem.
I think the thinnest panel they make is designed to have a 2x4 as a spline to hold them together, so that puts it at 4.5" thick. Of course, you can’t run down to your local big-box store and buy a 5’ x 10’ SIP, but the factory is only about an hour away from me.
What do you guys think?
I suspect a SIP would make a great Lowrider table. The Y plates want a table not more than 4" thick, though. You could but the bottom edge off on a 45* or so to accomadate that.
I think you should give it a try. 8^)
I was just thinking about this for a table as well. Has anybody actually tried it?
A few saw horses and a foam sandwich seem like an easy table.
Not quite sure what you are referring to here. I don’t see anything in the linked document (maybe I’m blind), and I can’t think how the thickness of the table would be an issue,.
Can you provide a quote from the documents to illustrate your statement?
Never mind, I see that this is a 4 year old thread. Let sleeping dogs lie…
So long as you have a way to securely attach the Y rail clips and the Y belts I don’t see why it wouldn’t work.
LowRider 2 that was. :smile:
