ok. I screwed up.
I was trying to get my Jackpot controller on my wifi, but when I saved it the fluidNC ssid was gone, but it looks like the board failed to connect to my new SSID. How do I fall back to the old wifi setup.
ok. I screwed up.
If your controller fails to connect to a wifi network, it should fall back to AP mode. Just look for a wifi called fluidnc it not you could use fluidterm to connect via usb. Just follow the instructions on FLUIDNC WIKI
Deleted
Jackpot CNC Controller - V1 Engineering Documentation, you can change the STA mode setting with the web installer tools as well, or just reflash it.
The web UI did the trick. I had to manually install the drivers because windows 11 didn’t do it automatically.
Apparently, I put this in “client station” instead of “client station (fallback to access point)” AND I had the wrong security type for my home wifi. It was the perfect storm. LOL
Thanks everyone for your help.
