What should I adjust in order to get my Z axis rails perpendicular to the Y axis (seems okay in relation to the X axis) - I’ve gone through some old threads but couldn’t quite determine how to move forwards as in loosen this, tighten that, double check something else.
I have always just adjusted tramming at my router mount, but that doesn’t square up the z-rails. Squaring the z could have some noticeable benefits for taller parts. I’m curious to see what methods ppl are using to do this. My initial thought is that tightening the core z clamps in the right order could have some affect. Along those lines though, I have noticed my z-rails don’t really touch the 4 inner bearings much if at all… appears the core is stiff enough to support the z using just the 8 outer bearings. So in my case I may not have as much “wiggle room” to adjust this. I am guessing this is caused by my burly mount being a bit too wide for the J for whatever reason (likely small print buggers).
Loosened everything, shimmed the Y tube a little on the XA XB side and a little finagling of the mount itself and everything seems a lot better, at some point I"ll rebuild the table and make sure it’s dead flat.
