What stepper socket does the Jackpot v1 board use?
Silly question, I thought it was the same socket as the SKR Pro but the plugs do not fit - I appreciate you can use dupont 4 pin plugs but by god I hate crimping those - thanks all :slight_smile:
Sorry just to clarify - not the stepper socket itself but just the stepper wire plug connection - thank you.
Pull the shrouds off the Jackpot and plug in your existing cables.
Of course - thank you!
Did you pull the shrouds off? If so would you recommend this to other people as like you I’m moving from an SKR board to a Jackpot controller and like you I hate crimping those tiny connectors.
Hi John, I did - they actually slide right off with very little force. They are not glued or soldered in any fashion to the board. Hopefully that helps.
