I will have to double check.
mine is the 2mm,
Cheaper and better, I always need metal so delivery can be free too. Thank you, I’ve not used this place before.
Here in the Philippines, I purchased 1" RSC electrical conduit. It’s 33.3 mm. I modified the braces to get them to fit.
I went to my local ace hardware in bc Canada and they had the 1” od conduit.
That might be problematic with the Y rail though.
Sorry my first post was misleading. Your right, I tried that and there’s no material left for the y bracket supports. I’m using 32.2mm for the Y-rail. But using 33.3mm for the x rails. There was not much left on the bottom x-support so I widened the area the bottom rail rides on to give it a little more strength.
I am still in the process of building this so let’s see how it goes.
This is also going to push the Y max side up since the rail can not go down.
Your brace parts will also have a lesser grip on the rail.
Unfortunately, I can not accommodate every rail size and there is always a trade-off.
Please do not publish your edited parts for others to use, as I feel it will compromise the machine enough to be noticeably detrimental.
Ah i noticed that too. i wanted the change to make as little or no impact as possible.
i made the adjustments to the xrail braces keeping the contact points of the bearings on the x carriage the same. i had to average the bearing contact points for the different size x rails and picked one in the middle.
the y rail config is standard.
In the UK, 20mm and 25mm are common for conduit, both stainless and galvanized. For the LR4 I just built I also managed to source 32mm from Rexel Metpro GC32 | 32mm Conduit Class 4 BSEN61386-1 3.75 Meter Length Galvanised Steel | Rexel UK
I made the max and min sizes it can handle, anything in between is fine, but above those bounds will cause issues somewhere.
I managed to find 1" IMC electrical conduit that is 30mm OD 1.9-2mm walls
Was looking to use 1" Schedule 40 stainless steel pipe which is ~33.4mm and slightly out of spec from the docs (32mm ±0.2mm). Fortunate to also have the correct size 1" EMT available locally. Any thoughts on the minor 33.4mm size discrepancy on the stainless pipe?
I would print a single strut and see if the pipe fits, Cinderella style.
I’m pretty sure 32mm OD is the absolute max that will work
The EMT is rhe right choice. There is no reason for the bigger tube.
