What is the command for returning to first surface scan point
In the middle of a project that requires tool changing… I forgot the command line command to return to the setpoint for the surface scan zeroing. It put the warning up the first time after the surface scan, but I stupidly didn’t write it down.
What is the two letter command!! Please anyone!??
Which controller are you using? Estlcam?
Uno/ESTLcam 12, and I did it for the first toolpath, I just had to swap tools, and need to repeat it for that toolpath. I remember there being a warning saying “Only use the command for this point, otherwise it will not be correct” it was a two letter command that you type into the command line. But I can’t remember it. I’d do it again but it is already center, and it was almost 400 points, plus it has toolpath 1 already completed.
You can just drive it to the new Z 0 and right klick the number.
Besides that you can mouse over the command line and it shows you all of the commands.
for some reason, I remember it saying that I can’t do that.
It warns you to make sure to do that after the tool change and not to 0 X/Y.
ok, sounds good, I’ll give it a go lol I stopped my second cut yesterday because I got scared.
