what a good router bit for 1/8 size Dewalt 611?
I just did the pen crown tested and now need help on buying a good 1/8" size bit for the DeWalt 611 router. I purchased the 1/8" collar from Ryan yesterday. I need pone for cutting plywood and one from cutting acrylic sheets.
Peter
I would start with a single flute upcut for plastic. I would also use that for plywood as well, you will hear people worried about tear out but in this case you can simply flip the wood over and cut the other side. I am not a huge fan of down cut bits.
Hey Ryan, I just placed an order yesterday, can I add more stuff to it…I didn’t see the bit you have in the shop. I will order some of the bits.
Peter
No I can not add charges to a card, the easiest way is for me to cancel the order if it has not shipped yet. If you give me the order number I will cancel it.
Since I myself have used acrylic sheets for wardrobe doors and all, I can help you with cutting it. There are too many ways experts use, but I would suggest sawing. Because you are in control of the action. Read this wikihow article for the method. https://www.wikihow.com/Cut-Acrylic-Sheets
