Wall Mounted MPCNC
I don’t have a ton of room in my garage, so I was toying with the idea of designing a wall mount for the machine. Has anyone tried this? I would guess that it would need to fold down from the wall to cut in the standard orientation because of the mass of the head…
I think you should just make it fit on a shelf, more than a folding version.
Mount two rails on side walls of your garage and build low rider for entire area :wink:
Would need a broom attachment… ?
Why bother with a tool change? Let the dust-collection system take care of everything.
You might get some ideas from the Maslow System… maslowcnc dot com. I think their frame takes up around 3 feet from wall, but not sure…
The maslow is designed to be hung though. The mpcnc isn’t.
If you were to mount it in a box on the wall so that the front of the box folded down and legs popped out to support it it would work.
You run into a problem with the height of the Z axis but in reality you could make it quick disconnect and pull it out to store the machine.
I say try it.
Yeah I was thinking about maybe getting ideas from the frame setup they use. Replacing their frame with a table that would lean out of the way when not in use…but that may be getting into the weeds too much…lol.
I’ve seen different versions of this idea used before with smaller CnCs
Fold up XCarve Table
I like that Joseph…here is another one… Folding table
The biggest issue with the Maslow is that the original wormgears are not available anymore, so to make it work, you have to partly “re-engineer” the build
I had ideas to hook up the motors on the concrete pillars on my porch. Super rigid frame, but scrapped the idea because of the motors, and the missing Z-axis. Didn’t check for a long time, but I think there were plans to implement a Z-axis too
Hey everyone,
Long time reader, first time writer,
I own a Maslow and am currently building a mpcnc. The accuracy on the maslow has improved significantly over the past few months (software updates). The Z-axis is implemented about a year ago.
The reason I am building a MPCNC is that 2.5D CNC is not possible on the Maslow due to the sled and it is mainly suitable for larger projects. Other than that it is a fine machine.
Hope to post some pics soon of a working MPCNC.
There was a guy on Reddit that had theirs wall mounted. He said he used some kind of weight/pulley system and it worked fine.
Hi,
Do you have a link to this post on reddit ?
Thanks
This probably isn’t better from a stress standpoint, but I saw this CNC Flip Top Table and it would help with space constraints since I could use it for workspace too. Do you guys think the main problem is the weight of the spindle? I could remove the spindle before flipping so that it doesn’t put too much tension on the belts. Then when it is upside down, the weight would just be on the opposite side bearings, not on the belts?
It could be possible to print 2 parts that lock the XYZ bloc on a corner of the frame.
I also seen a guy that used velcro straps to prevent the move of XY
Here is the post I seen
https://www.instagram.com/p/Bt6hjA2gW_f/
ALB - That looks awesome! It seems like that would take the weight off the belts really well and also prevent things from moving around. I will think of how I can make something similar work for me. Thanks!
Sorry, just came back to the forum today…
