Vinyl cut decal
I bought a selection of 1’x1’ vinyl squares and had a go at cutting decals using an Amazon drag knife.
Toolpaths were done using estlcam. They’re not perfect - there’s sometimes a ‘tag’ between parts but definitely fewer once I added a short lead in. Unfortunately this has to be done manually to every single tool-path so rules out more complicated designs.
The mount I’m using is a modifified version of Vinyl Cutter Knife Holder CR10S-pro (and many other) by TurtleCreations | Download free STL model | Printables.com which is okaaaay but there’s too much slop in the barrel, I can see the wiggle during short moves and changes in direction.
I have a modified print of Ryan’s one as well but I don’t like that I can’t get a good grip of the 2 knurled nuts when it’s cable tied on. I might make a sort of collet for the cutter. I do like the ide of using the PLA as a spring.
I do a bit of vinyl and htv for the girls! It gets easier! Looks good
I noted that the Cricut machines do some funky stuff at the corners to get sharp corners from a drag knife. Kind of like they go past it by the offset of the knife, then circle back to the line.
I still use my vinyl drag knife and Estlcam. I don’t add lead-ins, I just use an X-acto when I weed everything. The hobby knife helps pick out the vinyl anyway, so I’ve managed some fairly involved cuts, but the Estlcam ones always have slightly mushy corners. I got a Cricut as well, which does some heavier material, like card stock. Not quite enough to use a CNC, not easy to cut with a laser, too much trouble to manually adjust the drag knife. It does a nice job on the vinty and HTV, but I don’t like the software much, and the cloud concept doesn’t sit so well with me.
I think all it really needs is to overlap the start/end a little bit. But there’s no setting for that in estlcam.
Edit: the slop in the tool holder is definitely contributing. It needs to be a really good slip fit with no play. But I do like that I can adjust the spring the skin by preloading them.
Sign cutting software (i.e. that’s expressly made for creating gcode sent to vinyl sign cutters) has built in auto feature for this.
The VEVOR brand vinyl sign cutter I bought came with a license for SignMaster CUT v5. Pretty capable software.
The software I just mentioned, does this too, I’m pretty sure.
More trial and error required.
Luckily I have plenty more practice material to experiment on
The problem is that Estlcam has the correction for a drag knife in the controller options, but Fluid assumes that the correction has been made by the cam before and can’t change it on the fly. So drag knife wise Estlcam and fluid don’t work well together.
Back to using Ryan’s mount with a slight modification
Before
After
A small change but it means I can get more of a grip on the brass jam nut.
It’s maddeningly close but I’m still getting tabs even with a short lead in. Ah well
This is the source image
I’ve fallen down another rabbit hole to make a sping loaded completely constrained drag knife holder
Fwiw, am currently using the following mostly printed XY constrained drag bit holder. Mostly used for my diamond engraver bit to make specular holograms, but size the mount to hold drag knife too. I’ve yet to cut vinyl/PPF.
https://www.printables.com/model/419594-v1e-lowrider-3-pen-drag-knife-drag-bit-rdz-engrave
Short clip talking about more rigid v2 of this mod
Your linear rail setup looks to be even more rigid :eyes:
I have it left over from a prop build a while ago that’s the only reason I have it but it should fit the bill.
A more sturdy cutter holder is printing now and a selection of M2 (!) screws are on their way from Amazon.
Holy cow!!! Insane!
When the M2 screws arrive I’ll replace the back plate with a dovetail one - the only M2 screws I have right now are too long that’s so it’s mounted on the front of the sliding plate instead.
Happy with the cutting though, it doesn’t need lead ins and the corners are nice and sharp not vague like they were before
Spring donated from a pen if anyone’s curious.
SO. COOL.
M2 screws arrived so I can replace the mounting plate with a dovetail wedge.
I also had a brainwave about how to ‘spring load’ the cutter. The solution?
Loom bands! 2 cap head screws and looped over the top and if you want more resistance, add more bands.
Theres stacks more vertical travel than I need but that’s the linear rail I had so that’s what I used.
Safety… I don’t know, third maybe?
