V3 macros
I am trying to get macros working in V3 but it not simple pointing to the flash drive. Under the setting/interface page looks like you can add a macro. not seeing the correct set. I assume everyone is using macros in v3. Ideas how to setup or use the Macros?
I’m not sure what this means.
Macros in V3 are only defined in the settings, and are stored inside the preferences.json file.
If you are using V3, start with Ryans files in the appropriate folder to match your machine here
Those are the only files you need to start. Clear off any of the V2 files that were there before. Only the config.yaml is the same for both V2 and V3
If you start with Ryan’s files, you should already have macros defined as a starting point to use, and to use as a reference if you want to add your own
I did just that but did not work when I uploaded the files. So I just deleted the files and tried again uploading the files, now they work. Must have to delete the old files first. I will work on making my own macros now. Thanks.
