V1 Box - 10 Year Anniversary Edition
just anywhere? Hmmmmmmm I will try playing with it a bit. Thanks for the hot tip
Basically anything that is somehow connected to the endmill via metal. So the collet, in my case also the bottom case etc. There are also mods for the Makita to add a cable to the metal body etc.
Here’s the DXF for everyone that wants to try their hand on the box: V1 Box.dxf (285.4 KB)
If you want to see what I programmed - the E12 as a zip, including all the toolpaths. Before opening it, mind your EstlCAM tool settings. Normally it should open it as a new project that opens the tool list it was made with without changing your tool’s parameters (this is EstlCAM’s default setting): V1 Box Complete.zip (745.8 KB)
