First “real” project on my (Burly) MPCNC turned out great! I used F Engrave and MODfef per the first bit of the inlay tutorial. While it wasn’t the most optimized pathing and I needed to do a little bit of cleanup with a rotary tool after, I can’t complain too much for free software. Even got a tool change in without issue!
Carved with a 60 deg. Lee Valley V bit and 1/8" single flute bit. Black walnut with gold leaf. Letters are 100mm high (from top of “A” to bottom of “y”) 3mm deep.
I got mine from Michaels (Canada) but it’s sold all over the place. Make sure you get removable rather than permanent! I also finished the surface to 220 grit which may have helped it stick. Zero blowout; the final picture was taken immediately after removing the mask.
