My Z axis doesn’t raise a few mm after touching. so I went looking why.
when I was looking in the milling basic doc I noticed there is a difference in the G code between start and toolchange.
the start code says
G92 X0 Y0 ; Set Current position to 0 on the X and Y axes.
M0 Attach probe ; Pause to connect touchplate
G38.2 Z0 ; Probe down to touchplate
G92 Z0.5 ; Set new Z position to thickness of touchplate
G1 Z2 F900 ; Lift off touchplate
M0 Remove probe ; Pause and wait for touchplate removal
M106 ; This will turn on an IOT relay to start a router or vacuum
notice the G1 z2 f900
the toolchange g code says
M107 ; Turn fan 1 off IOT relay
G28 Z ; Raise Z axis
G0 X0 Y0 F2520 ; Drive to tool change side
M00 change tool, probe ; Pause to change tool and attach probe.
G38.2 Z0 ; Probe to touchplate
G92 Z0.5 ; Set Z to touchplate thickness
G00 Z5.0000 F500 ; Lift off touchplate
M00 remove probe ; Pause to remove touchplate
M106 ; Turn fan 1 on IoT relay
notice the G00 Z5.0000 F500 ; Lift off touchplate
Is this deliberate and if so what is the difference?
Personally I would not want a G1 command in a place where I want the spindle off… I would change that to a G0. Though G0 doesn’t guarantee (Or always even imply) the tool being off (Just a “rapid” move which Marlin ignores anyway.) Frankly though it’s weird, it should work to lift the tool. Maybe it’s having trouble with the higher speed (F900 v F500)?
I also tend to want to use a bigger gap. 5mm is good with the touch plate. Trusting the planner is OK, but there’s an M400 command to wait for everything to stop. I like to use this before any offset (G92) operations so that I’m sure that motion has stopped before I set any axes. Therefore I would use it before any G92 commands here. Can’t guarantee that this would make a difference.
But taking all of that into account…
M400 ; Wait for all planned moves to stop
M400 ; Wait for planned moves to stop
G0 Z5 F500 ; Lift off touchplate
