Has anyone set up a BLTouch probe (or knockoff) using the Mega/Ramps configuration? Would you please be willing to share the config.h & config_adv.h setup? OR would you tell me how to adjust mine in all the right places?
Well… I will share the Marlin that’s on my machine, but the BL Touch is not the only thing I’ve changed. I can’t remember everything I have. It might be a useful reference, it might just make it worse. It’s based off of bugfix-2.0.x as well.
There are several youtube videos and online tutorials about using it also.
Jeff
What mount did you use and what extruder are you using? I am using the cheap MK8 and will need a mount
I’m using an e3d v6 with a titan extruder. It’s a mashup of crappy and authentic parts. I can share my mount, but it will not work with the mk8. I think Erik has a mount for the mk8, but not bl touch. Kelly D has the BL touch and an mk8. I’m not sure what he’s using for a mount.
Jeff
Is this marlin set up for the Arduino or BBB? I am running the mega/ramps 1.4 and this doe not seem to work. Amy suggestions? Also, did you ever redesign the base under plate for the V2? like you made for the original MP3DP?
You really shouldn’t take this and use it directly. I’m using totally different parts, board, accessories and an unstable version of Marlin. You’d be better off getting something to work with basic marlin on your ramps and then find a tutorial for bltouch. If you are unsure, you can look at my configs for reference.
