I recently upgraded to version 12, and I am not seeing the tools paths like previous versions. Example: create a pocket and it shows the area in red usually. Now all I get is a change in the vector color. Is there a way to toggle this off and on? I am working on a lidded box and can’t determine if my “hole” not a pocket is as big as I want it.
It looks like you are using tools with different diameters (or cut depths). The gray path in the center of the red tool diameter (cut width) wide lines should look the same in v11 and 12. In v12 the grey path will turn geen when you move the mouse over it.
