I prefer to create a gcode file for every tool. Maybe another guy around here would helpyou but it is not that hard. Just add the toolchange code to your cam program (estlcam, vectric etc.)
If you are using the javkpor controller there is a tools command in the jackpot page from the docs
Looks like you are using the Jackpot. Assuming you have the tool change gcode setup like @CesarH mentioned in milling basics, when it pauses, you turn off the router, change the bit, attach the probe, hit resume in the Web UI, use the touchplate to complete the probe, it pauses again, remove the probe, turn the router back on, and hit resume in the WebUI.
I am using Jackpot, yes.
So I need to add the tool change gcode from milling basics into Estlcam and after that use the resume button in web ui under tablet tab and that is it?
Are you normally using the tablet tab? Which version of the WebUI are you using? I use WebUI v3 and there is a hold/resume button on the main dashboard page.
Not sure about version, but have it for few months from here. Maybe I missed the button, will have a look… I just know there is the button in tablet tab, that’s why I mentioned it
