Here is a super easy project, right in time for Halloween.
I’m using 2" foam from the big box. Get it in a 4’x8’ sheet and cut down to 16" x 24" so you can have 12 per sheet.
About half the time the sticker comes off easy, other times it adds more wear to the stone.
Spray the letters / engraving with spray paint. I used matte black
Use a roller to paint the foam. I used Gray Drylok since it already has a sandy texture.
I drill a hole in the bottom and use 10" of left over 1/2" conduit from building the LR3
Check out that scary tombstone.
