I’m trying to get my jackpot board up and running but I am getting a error after I upload the v2 and the v3 config from the GitHub link in the guide all 5 of the tmc 2209 aren’t detected when I run $ss and no USB plugged in powering from a meanwell power supply
I got the esp32 from amazon it’s from the manufacturer
And the tmc2209 v1.3 from big tree on amazon
My $ss
[MSG:INFO: FluidNC v3.9.1
[MSG:INFO: Machine MPCNC]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: X2 Neg Limit gpio.35]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Y2 Neg Limit gpio.34]
[MSG:INFO: Axis Z (-100.000,200.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Z Neg Limit gpio.32:low]
[MSG:ERR: X Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: X2 Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Y Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Y2 Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Z Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low
Nothing I’ve tried works and if I try to move the x or y axis 100mm I get 100mm from x1 and 50 mm from x2 or the same thing but 100mm from y1 and 50mm from y2
Thanks
They may be configured in “standalone” mode. There are some little solder pads that change it from standalone to uart mode. The drivers won’t listen to UART if they are wired for standalone. The rest of the symptoms could be caused by that.
I have circled the pads I have tens tmc2209s I have 5 with that jumper soldered and 5 with out it soldered the 5 with the pads soldered are for another thing and need to have them soldered. But both sets give the same error in the jackpot boar.
This is a tough one. If you have a multimeter, make sure the top right corner pin of the drivers are getting power.
I am guessing maybe this needs to get returned as I am out of ideas but it sure feels like we are missing something simple. All 5 drivers should not be bad at the same time. 3 or 2 makes sense but not 5. Maybe using the soldered drivers popped the uart chips on the jackpot?
TMC2209s need to have working UART communications in addition to EN/Step/Dir bits. With any of that not working, it’s not going to be a functional machine. If UART comm is dead, then that has to be fixed before making any more progress.
Sorry I’ve been dealing with really bad weather.
So no USB cord plugged in. I tried a set of tmc2209s known to be in uart from a working mpcnc jackpot board that my brother has and still same thing. I will post a picture of my file system In a few mins
