Hi, I’m doing a dry fit of LR3 and the core fits extremely tight. I loosed completely nuts for bottom bearings before even could slide core a little bit on the tubes. Also core scratches the braces a little bit.
I’m using 25mm tubes (measured outer diameter)
Printed 25mm braces (text on the braces “25mm OD”)
Printer is squared
Here is the space between bottom bearing and the core - is it ok or there should be no space betwen bearings and nuts/printed part?
I see the max difference for 0.3mm on the longest side of the brace. And that’s probably because of “elephant foot” on the first layers - but they are not the biggest points of contact. Other dimensions fit 0.15. What the acceptable tolerance?
