I was at my local nuts and bolts store yesterday here in Manila. I was looking for thread rod to run a cheap plywood frame 3040 CNC. I had had issues with whipping of the previous machine builds that used m8 rod with a 1.25mm pitch. So I picked up some m12 with a 1.75mm pitch.
they also have up to 30mm thread rod in stock.
I am thinking of going up to 16mm thread rod with a 2mm pitch for a future build.
has anyone messed with the larger thread rod for CNC machines here?
For x and y you’ll get whipping even with the bigger threaded rod. None of it is perfectly straight, so you’ll induce some centripetal forces when you spin them. That’s why pretty much all of them will use lead screws, which are ground straight, or belts, chains or a rack and pinion gear assembly.
Bigger rod is higher pitch which is less turns for same movement which equals a lower turn speed of the rod and less whipping along with the added stiffness…
Yes I am very familiar with ball screws and acme screws. I buy them all the time from China.
I build and service CNC routers, 3D printers and co2 lasers full time. This however is my search for a very low cost machine that does not need the China imports.
The ~600mm/m max on Z is due to the 1/32 stepping on the drivers and the Arduino running out of puff generating the signals needed. I’ve set mine to 1/8 stepping and can get ~840mm/m, it’s not 4 times original-speed because of the mechanics, but the CPU seems happier with cycles seemingly spare now and it’s a nice speed upgrade. With larger thread, expect more friction, and I guess don’t expect twice the speed.
